robbob2112
Doing more research, mosty harmless
Looks like this.
Green is battery current. This is for low freq inverter. High Freq inverter will not have the negative battery current for poor AC load power factor, it will flatline near zero current for the short backwash period .
Little side association, a battery monitor for current requires heavy filtering (low freq cutoff filter corner freq) to average out the 120 Hz ripple current. Typical low pass filter has a 1 or 2 Hz cut off frequency. These days it is often averaged digitally in the microcontroller.
Much better diagram to explain things
See - I hadn't even considered PF in all of this - I knew it factored in but not how to apply it. -- This sort of math is why I switched from EE to CSE in my second year --
