Wondering if the solar brain trust can please provide commentary/advice on my proposed design for adding two additional PowerPro batteries and an additional Chargeverter, to my current system of three PowerPros and one Chargeverter.
Here's the current layout, which parallel the PowerPros as recommended by EG4 and Current Connected, and which makes use of a Victron Lynx (1000 amp busbar) to connect the Chargeverter to the PowerPros. This works perfectly, with all batteries charging and discharging equally whether from solar or via the Chargeverter.
But with winter coming, I'd like to add more storage and make use of our available generator capacity (10K running watts) via an additional Chargeverter. Because I have only two open "slots" available on the Lynx without doubling up on connections, and need to connect three things (two PowerPros and an additional Chargeverter) I've come up with this as my "desired" design. Will it work, without causing a big problem (e.g., batteries not charging/discharging at fairly equal levels)? Comments welcome and appreciated. Thanks in advance.
