Will this work?
DenverGuy
I bought an Epever 30A MPPT controller for a four 100W panels. I considered the input amperage but not the input wattage. The max input is 390W. I know the that the panels aren't 100% efficient. Will this work, or am I too close to the limit?
sunshine_eggo
Happy Breffast!
USA
Will work fine.
It's not at all uncommon to "over-panel" a controller, i.e., put more wattage on it than it can deliver.
As long as your don't exceed the PV input voltage limits or the PV input current limits, you're good.
DenverGuy
Thanks, that's reasuring. How much wattage could a 100W panel actually produce?
I bet it's a lot less than 100 watts.
sunshine_eggo
Happy Breffast!
USA
It depends completely on circumstances. A number thrown around is 80% of rated.
Ratings are based on conditions that don't usually happen in the real world, but sometimes a combination of circumstances can even allow GREATER than rated output. My 3kW array briefly put out 3.6kW (+20%) due to extreme cold. Cells were below freezing, and the panels are at 6500' elevation, so the atmosphere is about 15% thinner. Combine those two factors, and I was able to get 3600W in December - 5 days from the worst solar conditions of the year with the panels tilted for "year round" performance. But that's not typical.
Most panels have a NOCT rating, which is a more realistic performance number.
