Will's Yixiang DIY box video
Mops9
Texas
I follow also Andys garage who is a big fan of this box. Interesting to see what Will likes or not about it. Appreciate the different takes.
However, I also found Docan on this forum and I just got this from them. $1400 for an assembled 15kwh box....
@Will Prowse - can you explain how to connect this BMS and close loop communication to the flexible 21?
I asked because if you have different communication types for batteries in your vault, are you simply using voltage instead of soc?
Oh gosh I did not try that. I hate communication really.
Those are all voltage controlled. I connected the flex boss to the EG4 batteries recently because I set up solar assistant.
With dissimilar batteries I would just use voltage.
Can you do a video series on setting up solar assistant?
I don’t think you’ve ever done that
