Rednecktek
Solar Wizard
So my neighbor is trying to get a micro turbine on his spring and I'm trying to do the research on the wiring involved. Right now I think he just has a AC->DC 3ph rectifier and he's trying to pipe that into a solar charge controller.
Fortunately for me he's still in the parts & assembly phase and hasn't set anything on fire yet.
I had a thought though, if a micro turbine is basically a car alternator (OK, his is) with paddles and a wind turbine is an alternator with wings, could he use a wind turbine controller on the water turbine? Would the braking control do the same thing or would it not work to stop the water turbine from overcharging the batteries?
Does that make sense?
Something like the Garosa wind/solar hybrid controller or, when we revamp his solar setup to a 48v system, something like the Furnoor Generator at 48v and parallel the outputs to the battery banks.
Or am I about to divide by 0 on this?
Also, does such a beast exist that is a MPPT controller with the 3ph AC input built in rather than the PV input?
