svetz
Works in theory! Practice? That's something else
What you want to do is get rid of anything where the force would try to pull the screw/lag out, that is the force runs parallel to the screw. Ideally, the force is perpendicular to the fastener so you're relying on the thickness of the fastener for strength (e.g., the shear strength). When you can't do that directly, typically you use some sort of "hanger" that essentially straps it in against the forces, and lets the hanger's fasteners be perpendicular to the forces. Most common are joist hangers, but you can find all sorts of types or make your own. There are a few common hanger types in the image to the right. |
Steel brackets might work, but only use fasteners that might pull-out if perpendicular to the forces (not always easy to tell with wind that can come at you from any direction). Otherwise bolts with fender washers (extra wide washers to increase surface area)....Would some 90 deg. steel brackets help a bit, d'you think?
