I have an old 48v wind turbine power generator that was in use on my system when it was on flooded lead acid batteries. Since I upgraded to LiFePo4 batteries I havent reconnected it.
I'm wondering if it would be safe to use it on the new batteries. My understanding is that it has its own charge controller built in and auto-brakes (stops generating) when the battery voltage reads 55V. That is a little above the float value for my batteries but below max charge.
I also wonder if my battery monitor sensor wires could be used to track its power generation. I dont have a separate shunt for it but it was connected to an analog Amp meter. Might the two terminals on that work for the two sensor wires on the battery monitor (Flexnet DC) or does it need to be a regular shunt?
