Here is the production data for this January from just my 4,800 watt Enphase system.
I would say just 2 days I could call bad, the rest was very good indeed. Total production of 462.8 KWHs is the best January I have had since 2022 when it did 479.1 KWHs.
The average ended up at 14.93 KWHs per day. Several days went over 17 KWHs. And this is the AC out of the inverters, and heavy shade on half the array for 1/3 of the day.
Here is the charts of the DC array production.
The garage roof 2,000 watt array did a lot of "floating" so total production could have been a lot more.
I'm too tired to go through and add up all the bars, but it looks like the average production was over 4 KWHs a day, the peak went over 6 KWHs a day. Not too bad for just 2,000 watts of panel off Amazon.
The 4,000 watt Pergola didn't go online until Jan. 12th, but I did have a few panels going through the new Victron 250/70 for a few days before that. You can see the first few days of a little production from only 3 panels against the wall.
Total for the month is only 260 KWHs, but this array was only up for 19 days and it did a huge amount of "floating" while the battery kept getting topped out very early. After the battery ran down in the rain storm, it managed 16.95 KWH even with floating for a couple hours. Once I actually start using all the energy, it is going to really be cranking out the power.
This is kind of funny. I took a screen shot of the Schneider XW-Pro "Energy" page.
Grid Energy used Current Month, the bottom right box, 25.5 KWHs. This is all the energy that had to come in from the grid to power loads in my backup panel that the batteries didn't cover as well as all the grid charging I did on the rainy days. There is also some added in here from when the XW was doing the crazy oscillations. That total for the whole month is less that my house normally uses in a single day.
Battery Energy (Charge) Current Month, Black box middle right, 86.7 KWHs. This was from the grid energy, AND the extra coming in from the Enphase system at the output of the XW-Pro. It is the total energy the XW-Pro put out as DC current to the batteries. It will actually be even lower now as most of the time, I am turning charge off in the XW and just letting the DC systems do it.
Grid Energy (Sell) Current Month, bottom left blue box, 349.4 KWHs.
This includes energy from the Enphase system that went through the XW-Pro back to my main panel as well as any energy inverted from the batteries that went back out the AC1 input. I don't get credit for all of it, because this did not subtract my loads in the main panel. So where did all this energy come from?
Battery Energy (Discharge) Current Month, Upper left grey box, 507.4 KWHs. This is the source of the energy that the XW inverted to AC for both the load output panel and pushed to the grid in the evening. This is 421.7 KWHs more than it charged into the batteries. That energy all came in from the two Victron charge controllers. 260 KWHs from the Pergola system, So that leaves about 160 KWHs that had to come from the garage roof system.
