Guillaume.l
- Sep 3, 2022
- 3
Hi there.
I am sharing here my project of upgrading my solar energy system to get advice from knowledgeable peoples from this forum. There is a real possibility that I have misunderstood some things and planning something crazy. Any correction of comment will be greatly appreciated.
Context:
I am located in Europe, near Mediterranea, in an area that has excellent potential for solar (> 1600 kWh / kWp / year).
I already have a small self consumption installation running since a few years. Around 2400 kWp of second hand panels with enphase micro inverters (M215) that produce around 3000 kWh / year. In summer, we generate 14kWh/day with this array. We are consuming around 30 kwh/ per day in average, so there is room for more solar power.
Main consumers at home are swimming pool filtration (mostly in summer), water heater and (small) electric vehicle.
nearly 95% of current production is self consumed by running load based on available power with home automation system, and routing surplus to water heater.
I am pretty convinced that electricity price will be high in future, so I am seeing solar a good use of some money I have available that is currenlty being eaten by inflation.
Objective:
The plan
Plan is to build AC coupled system because of the flexibility of wiring. DC coupling would be quite complicated to install in my home. Being in series with grid vs parallel to grid means bigger inverter, but necessary to have UPS fonctionnality.
I am still not sure if current sensing clamp is necessary in this configuration. Neither If it will be possible to avoid back feeding to grid when batteries are full. I am not supposed to feed back excess powder to grid, but energy company is not measuring (yet), so not a big deal.
Looking at power curve of house, I am confident that 99% of time we are under 5kw. Yet, once in a time we have temporary surge in power use over 5kW for few minutes. Not sure though if powerAssist functionality of Victron can use AC from grid when demand is higher than what inverter can provide. Only using battery to assis AC is mentionned in documentation.
Victron multiplus-II 5000 W 48V, wired in series with grid would be heart of system. My understanding is that max solar power I can install is 5000 Wp to respect 1:1 rule. Or is the limit of solar constraint by charger ? This limitation only applies to off-grid situations.
A GX device is apparently needed for this setup. My plan is to use raspberry Pi running venus OS to save some money here. Interface between raspberry-pi and multiplus would be MK3-USB interface. Not sure here if
Battery will be self assembled LiFePO4 .16S 280Ah. Still not sure about BMS. Currently leaning toward JK-BMS. Still not clear is it would be doable to read value from BMS from raspberry pi to feed it to openhab.
Context:
Objective:
- Have fun with DIY project
- Increase solar power to 5 kWp to cover most of our electricity need. I am not after going off grid. That would be cool, but not really make sense economically to my opinion and don't want to be in darkness when I will blow something on my system
- Install battery system to optimize self consumption of solar energy I produce
- In case solar was not enough to top it off during day, be able to charge batteries at night to take advance of cheaper electricity cost,
- have UPS capability, especially to be able to keep pellet stove running in case of blackout (winter is coming)
- Be able to charge batteries while being in off-grid mode (in case thing go really bad this winter)
- Use grid to run home when batteries are flat and no solar available
- Use grid when home need more power than inverter can provide
The plan
