In principle, and from everything I've read (and done) it should be fine.
A source:
https://www.solacity.com/how-to-keep-lifepo4-lithium-ion-batteries-happy/
Quote: "Storing batteries below freezing is fine, even at very low temperatures such as -40 Centigrade (that is the same in Fahrenheit), or even less! The electrolyte in LiFePO4 cells does not contain any water, so even when it freezes (which happens around -40 Centigrade, depending on the particular formulation) it does not expand, and does not damage the cells."
Also: " Storing them at low temperatures is certainly much better than storage at high temperatures: Calendar aging slows down dramatically at low temperatures. " --> so it might even be a good thing!
