I just picked up an AIMS 75 amp 12/24 volt charger. I have two sets of batteries to charge, 1: a 24 volt eg4 LiFePo, and 2: 4 6 volt lead acid golf cart batteries in series/parallel for 12 volts. What size cables should I use to connect the batteries to the charger ? I have a 1/0 and a 2 gauge set but both have ring terminals to big to connect to the charger. The wire ampacity charts look like 6 or 8 gauge should be fine for both battery packs, (at 37 and 75 amps max respectively) especially if I turn the charger down from max amps, but I'm a bit confused about the chassis and transmission ratings in the ampacity charts.
The golf cart pack is at my off grid cabin, so I'll be using a generator to get those up to capacity.
thanks
thanks
