Hi
I am working on my wiring plans for my battery boxes. will be making two of them over time Have a few ?s
Here is the plan does all this look right.
A 12 volt 100AH battery system with no inverter just 12-volt sockets. using an SKO Lithium Iron Phosphate Battery I ordered.
Will be ordering the recommended TEMCo 10 AWG/Gauge wire to go to the solar panels and crimp on my own solar connections.
Then the same wire with the solar connections coming out of the solar charge controller to hook to.
Then the same 10AWG size wire going out of the solar charge controller with an Anderson power pole plug on the end to plug into the box I am making.
? On the box I will have the other end of the Anderson power pole plug to plug into. My ?s here is going from this end of the plug to the battery with a fuse in between can I also use the same 10AWG size wire or should I use a 6AWG size wire here? So this would be the Anderson power pole plug to battery round to hook onto the battery.
Then I will wire in 3 cigarette plug sockets, one fast charge dual USB socket, a power switch, and a battery monitor gauge all with a fuse block.
? can I use 14 gauge wire for this for all the sockets and power switch and fuse block?
Then I can put on an Anderson power pole plug on the end of an AC charger 20amp to charge it from AC whenever needed.
I have all this sitting my amazon cart ready to buy but wanted to make sure this is the right wires to get.
Am I missing anything in this box build?
Thanks
Thanks
