Hi there, I have a 500W inverter I am planning to power with 280aH array of 4 cells and a 100A BMS.
Doing the basic calculation as follows 500W inverter max load/12V battery = 41 Amps. I need a wire thick enough to carry 41A
Based on Will's advice in his book, I based my max load on the inverter and ordered 10AWG wire to connect the BMS and battery to the inverter:
"500 watt inverter requires 10 gauge"
and further for the fuse, I purchased a 50A:
"500 watt inverter should have a 50 amp fuse"
here is wills chart
Going off of this, my wire will burn out before my fuse?
This one has its max current at 30A
here is wills chart
- However, doing an image search I have found charts that do not clearly indicate that 10AWG can carry this current.
- Google search indicates max current of 10AWG is 40A - Some results indicate only 30A
- https://www.engineeringtoolbox.com/wire-gauges-d_419.html (3 cores can only carry 30A, single core can carry 52A)
