So I'm preparing to order stuff so I can wire up my new trailer. And I have a question that I can't find an answer to, which is: How do I size the wire used to power a motor with DC power? I understand that electric motors require more current on startup. In solar systems those motors are usually run off the inverter and the wire running from the battery to the inverter is of course sized for the inverter. No problem, lots of advice on how to do that.
But I've also got two small travel fridges that will be powered via a DC connection. If I understand the situation correctly, they use brushless motors, and I think those motors will require a higher-than-rated current draw when they start up. For the sake of discussion lets say that they normally use as much as 3.7 amps, but at startup they could use 20 amps (that's what the person on amazon's Q&A said for this product, though the startup current seems high to me...). Anyhow, I understand I'd want to size the fuse at 3.7 A X 1.25 = 4.0875...so lets just say 5 amps. And I understand that I should use a slow-blow fuse for this, so that the startup current doesn't blow the fuse. But what I don't know is how I should size the wire. Should the wire be sized for the 3.7 A which is the normal draw? Or should I size it for the peak draw?
Thanks yall!
Thanks yall!
