The System:
Inverter: Growatt SPF 3000TL LVM-ES, max PV input voltage(VOC) 250VDC
Panels: 410watt, VOC=49.4V, Short Circuit Current=10.59A
Distance from array to inverter=30 ft
Currently have 5 panels in series for about 226V on a sunny day, read at Growatt Inverter.
Also read at Inverter shows about 1.8A on a sunny day.
Doing math, 226V x 1.8A = 406.8watts, make sense since it is close to my 410watt panels.
Have 4 unused #12 thhn/thwn 600v wire burred in conduit from a previous project. Originally calculated wire size for
10A at 250V at 30ft. , resulting in a pair of #12 wire would be fine for 5 panels in series.This was believing that there would be 10A.
Then when seeing the inverter showing 1.8A, I conclude that since I raised the voltage 5times (series connections), that the
ampere of the panel was reduce by an divider of 5.CORRECT?
Am adding 5 more panels in series for a set up of 5series 2 parallel. Am I correct in assuming that I can still use the original pair of
#12 wires to carry voltage from array to inverter, instead of using another pair of #12 wires? CORRECT? Using 1 set of #12 would be
easier and less wiring.
Trying to understand some basic concepts. Any thoughts and comments are much appreciated.
