Hi everybody, I am a bit over my head with installing a solar array of 2 400 w, 24 v modules. I am hooking them up in parallel and don't kno wthe cable size from there on, to my 4 12 volt 200Ah AGM Renogy battery bank. Will a 6 gauge wire do?
And do Ineed n inline fuse between the array and the 80amp charge controller?
The inverter is a 2500W 24 v.
Inverter and charge controller are an All in One unit that was recommended by Will Prose. The batteries are in series and parallel, to meet the 24v. Are the automotive battery cables of 4 gauge enough?
And again, do I need to put an inline fuse between charge controller and batteries? What size?
And what size cable will feed from the batteries to the inverter? Fuse there as well?
It would be awesome to figure this out, so I can finally mount my modules on my cabin and have sufficient power to hopefully run a 110 v, 4amp convection heater for a few hrs in the early morning and a 1500w, 110v vitamix for a min every morning, as well as have a booster plugged in for wifi, when needed, possibly 2 hrs a day.
Are these loads too much?
Thanks for listening.
wren
wren
