I have a roof top junction box, I need to have bare pv wires enter the junction box, how to create water tight seal.. or is there a way to have them enter conduit with bare wires that will create a water tight seal then go into the junction box?
Multi-hole glands allow multiple wires to pass through a single secure cable gland connection. Shop our large selection of cable glands and cord grips. Order now.
Ohh also, I am using the gray flexible conduit to go from the box on the roof to down the side of the building into a disconnect, the box on the roof will be within 12" of the edge of the roof (panels will cover it), do I need a conduit strap on the roof itself or can I start using them once I get off the roof and going down the wall?
I would not go through the roof.
I would place the tubes/cables over the edge of the roof and onto the wall under the overhang and then go into/through the wall for less possibility of water intrusion.
With cable glands or similar + silicon etc.
