Wiring a 6 into 1 combiner box wire size.
Watch Me Build
Screenshot_20221207-231247.jpghere's the specs on the panel. Trying to do s2p6 into the combiner box. So 12 panels total.
The run from the combiner box to the PIP 3048LV-MK is 30 ft. Can I get away with 6awg wire? And what's the most cost effective wire I can go with when running through underground conduit?
Also what gauge wire from the panels to the combiner box?
6 ga. wire is rated at 60 amps maximum,
calculation.....6 X 10.10 ( worst case short circuit current) = 60.60 times 1.25 safety margin = 75.75 amps
also in the NEC....continuously operated device , i.e. able to operate at maximum power for more than 2.0 hours requires an additional ampacity of 1.25 ............thus 1.25 times 1.25 is 1.56 .....1.56 times 60.60 is 94.68 worst case current....94.68 amps worst case 2 ga barely makes it
.however this worst case is very unlikely to occur in a solar installation since operating at short circuit over 2 hours is so unlikely the more correct calculation would be 6 X 9.58 X 1.25 =71.85 amps 2 ga. will be fine here
individual series panels to combiner 10.10 amps times 1.25 is 12.65 amps normal maximum current 14 ga wire is rated 15 amps under the NEC for household use
Best wire type THHW (thermoplastic-hot-hot-weatherproof) 105 deg C
assuming underground conduit....assumes water....waterproof wire required
for dry conduit THHN (thermoplastic-hot-hot-not weatherproof)
THHN and THHW is commonly available at home improvement stores
I was going by this chart, for the THWN-2 (the 90° C heading) . That's why I thought I could get away with the 6awg. Maybe the 4? The 2 seems like overkill going by this.
Chart
ABYC chart says 70 amps with 90c wire AWG8.
ABYC is the American Boat and Yacht Club
That has nothing to do with NEC as required by the building department and household insurance.
I did assume we were discussing a dwelling
And you did forget the NEC required multiplier 1.25 times 1.25 equals 1.56 times maximum continous amps @2.0 hours
Okay, but he's going to have to downsize to 8 gauge to fit it in the charger.
Don't think he's looking to get it permitted and inspected using an MPP solar unit.
Yeah, no permit or inspection, but I do want to do it correctly.
8 awg, definitely isn't large enough for the panels I have
The other thing is the insurance......most have in the agreement ”compliance with the code”
Not everything that I do is “exactly code” but so near that the inspectors let me skate on not being permitted
My system is all U.L. listed, made in America,
Hmmm.......Schnerider Electric, Magnasine, Trace, Exeltech, Morningstar, Interstate Battery, Tesla 18650 and 20700 cells
<EDIT> dont know how I missed Midnight solar in there...inverters coming soon
Many manufacturers out there
my main bank of batteries are cnuk.....Rolls-Surette
All of my American gear has far exceeded expected lifetime
None of my chinese gear has made it one year
Personally I am running my panels 2S due to the fact that the voltage conversion ratio of 72 volts to 28 volts (2.5 to 1)is far more efficient than 108 volts to 28 volts (3.85 to 1) more efficent equals less generated heat equals longer life.
I have long life gear
Never had a power outage on main system since its been All-American
I just knew that was coming with emphasis on electric vehicles.
Crown, Gillig, and BYD Busses are all LFP as well as most of the yard tuggers (mini tractors that shuffle containers around at the ports are LFP).
BYD (China) has built a transit bus factory in Lancaster, California to serve American and Canadian Transit Markets.
All their busses are LFP.......the first busses that have passed all NTSB testing at the first pass, rollover, crash, fire safety, etc.
Dude, hijacked his thread. This one's not about you.
