Just_Askin
Here is the spec sheet from my panels
I have connected 2 panels in series (with panel's 10 awg wire) and then the 2 strings in parallel (with 50a branch connectors and 8awg wire. I am planning on using a 500v 63a breaker as a disconnect switch between the panels and a 150v 70a SCC. Do I also need a fuse or fuses in addition to the breaker? Does what I've done seen safe so far?
