Thank you for pointing that out rmaddy, I've looked at that battery so many times now, I am not sure why I thought it ran on 24V. Silly mistake.
Right now I am planning on purchasing 4 more of the 12V 100AH SOK batteries to pair with the 4 I already have in a 4S2P configuration, I am also planning on purchasing the autotransformer as a solution to needing the two legs of 120VAC here in North America.
I do have a new question however, as I am trying to work with the man who just installed a deep water well on my property. Initially they thought the well would need to be 120 feet down and would require a 120V soft start pump. After actually drilling the well ended up being 500ft deep. The most simple solution they said would be to use a 240V soft start pump. I feel like this is a stupid question to ask, but if I am using the autotransformer will I still have the option to run a 240V pump off of the inverter? or will the autotransformer mean that's no longer possible?
Thank you all again for your input, this has been very helpful
