Simon E
Hi all,
I am planning on building out a van and need some help discerning how exactly amperage works with a 12v DC system.
I am charging the Bluetti AC300 + B300K with 400W of Solar. I am then running 12v puck lights, a 12v refrigerator, MAXXAIR Fan, and a 12v Water Pump off the AC300.
Total Amps being drawn at max (according to manufacturer) are:
Puck Lights: 1.25 Amps
Refrigerator: 5 Amps
MAXXAIR Fan: 5 Amps
Water Pump: 6.75 Amps
Total: 18 Amps
I am running each circuit for these appliances through the Blue Sea Systems 5026 ST Blade Fuse Block, Then the fuse block will be connected to the AC300 12v DC Output, which is rated for 30 Amps. I am using 8 AWG wire to connect the Fuse Block to the the AC300 12v DC Output. I am then using 14 AWG wire to connect each 12v appliance to the Fuse Block. 4 total circuits being used.
My question is this:
The 12v DC Output is rated for 30 Amps, do I need to run wire that can hold 30amps (8 or 10 AWG wire) to each of the appliances or is 14 AWG sufficient?
Do I need to size the wire according to how many amps the appliances draw? or do I size the wire for the 30 Amps the 12V DC Output?
I am very new to this, I really just want to know if this is going to cause a fire or not. Thanks!
MAXXAIR Fan: 5 Amps
Total: 18 Amps
