In a 50 amp split phase Victron Multiplus II setup, I would like to use only one leg of the AC out 2.
On the Multiplus AC Out 2 connection point, I will only connect wiring to L1 and Neutral and earth, and will not connect wire to L2.
Sorry for what is probably silly question - is this the proper way to use only one leg from the output?
thanks
Jeff
thanks
Jeff
