Coydon
Over Easy
Is there a good generalized resource that lays out all the factors to consider when building a DIY battery box? I've been looking through threads and videos for a while to find a simple but robust design I could adapt but found relatively few things applicable. Invariably I end up wasting hours down some tangential rabbit hole instead of tracking down relevant info.
A couple months ago I found a video from this older British (Scottish?) gent that was working in his barn (seemed a bit cold, he was wearing a knit cap) who had what was the most appropriate wood box design I've found to date, but now can't find it in my history or come up with the same search terms. Does this description ring a bell with anyone?
My thoughts on a design are that I would like a basic compression design like in the above mentioned video, two end boards connected by four threaded rods. This design was not entirely closed, so would hopefully be able to deal with excess heat passively. I would then build a larger exterior box to drop this into that would have thermal panels in the bottom to provide for colder weather.
Would I need a full enclosure for warmer weather? It will be in a shed that is exposed to dust, insects, and rodents, so wondering if I need a 'summer box' that has some screening? How much better to have a fully enclosed box with a computer fan intake and exhaust to limit dust exposure? Thinking the fan might still pass some dust and need periodic cleaning itself. What does dust do to prismatics with an Overkill BMS attached to them, is this a big concern?
What are the merits of including the BMS and/or other components like a monitor, charge controller, etc. in or on the box vs nearby? I'm trying to picture flexibility of battery placement, but not experienced enough to have much to go on. I have a root cellar nearby if that would address the heat/cold extremes better, but not sure how practical that is with various wire lengths.
