My batteries arrived (without the busbars, studs/nuts ?) and the voltages were IDENTICAL at 3.293 across all 4. The terminals all looked clean and threads looked good. 2 of the cells had some swell to them, Ninthcit says these images are normal, but not sure if I'd agree. Going to be used in a van setup. Also,one cell has an odd lamination of the blue wrapper to the casing.
Maybe once I get the busbars, do a compression between plywood with then balance? Problem is that I can't even balance until they've sent me the bus bars (my first time doing this so I don't have the hardware...)
