TiagoGomes
Good afternoon,
I recently acquired a Solis S5-EH1P5K-L inverter, which was installed and configured by a company specialized in this type of service. Overall, I’m satisfied with the equipment’s performance; however, im having a problem with the load usage that I would greatly appreciate your help in clarifying the issue. I’ve already tried getting answers from the installation company, but unfortunately, they were unable to provide a clear explanation.
I’ll try to explain as clearly as possible the issue i'm facing with the inverter: I’m about 99% sure that the household consumption readings during solar production are incorrect. That is, the higher the solar production, the higher the reported household consumption. I even ran a test where I turned off all the circuit breakers in the house and, for example, if the panels were producing around 4 kWh, the inverter indicated a household consumption of about 1.5 to 2 kWh (approximate values, and yes, with all breakers off).
Another example: household consumption with only the essential devices connected is around 0.4 to 0.5 kWh. If I turn on a dishwasher and a washing machine (assuming each uses about 1000 W) and the panels are producing about 5 kWh, the consumption reported jumps to around 4.5 kWh, when it should be approximately 2.5 to 3.0 kWh.
(I know the 0.4 to 0.5 kWh baseline is accurate because I previously had another brand inverter for three and a half years, and that value was consistently observed, just like in the two scenarios I mention below.)
I believe all settings related to the Meter are correct because there are two situations where household consumption is reported accurately:
What it seems like to me (even without much technical understanding) is that when the batteries are at 100% and solar production is active, a significant percentage of energy is being "dissipated" by the inverter (if that’s even possible), instead of being exported to the Grid. And this “dissipated” energy is being counted as household consumption. What I want is for the reported household consumption to reflect only the actual consumption, not the real usage plus some "dissipated" energy.
Could the issue be related to the Grid export settings? or is there a setting that limits the amount of kWh that can be exported to the Grid? If so, is it possible to adjust or disable this limitation?
Here is a Link to a short video I made (recorded on a partly cloudy day, which explains the solar production fluctuations). It clearly shows that whenever there’s a rise in solar production, there’s also a significant increase in the reported household consumption, without any additional devices being turned on:
If you need any further information from me, I’m happy to provide it.
Thank you in advance for your attention!
- In the morning, while the batteries are still charging;
- At night, when there’s no solar production and the batteries are powering the home.
