[WTS][PHX-AZ] ROCKPALS RP100 100W Portable Solar Panel
bosun120
Images (can also send verification upon request)
Selling $150 + shipping in CONUS. Please PM me with any questions or details.
New in box. Great for camping or overlanding.
[2022 UPGRADED FOR SOLAR GENERATOR] Rockpower RP100 solar panel charger 100W is compatible with the most solar generators on the market(Anderson connector charaging power station, 5.5*2.1mm DC for ROCKPALS 250W and PRYMAX 300W power station, 6.5*3.0mm DC for ROCKPALS Freeman 300W or 600W portable power Generator, 8mm DC for Goal Zero. With a parallel cable (sold separately) connect 2pcs 100W newer solar panels to produce more power.
[HIGH CONVERSION EFFICIENCY] Rockpower newer solar panel foldable has up to 23.5% high conversion efficiency, perform better than other conventional panels in sun. Ideal for outdoors camping life.
[4 TIMES FASTER CHARGING] Rockpower 100 watt portable solar panel is equipped with 1* USB QC 3.0 and 1*USB C Output (PD supported, 18W output max), provides 4 times faster charging speed for your smartphones, tablets, DV, GPS, digital cameras, etc.
[PORTABLE & FOLDABLE WITH KICKSTAND] Rockpals solar panel 100w is foldable and only 9.48 lbs with an easy-carry handle. Slightly adjust the angle with the kickstand, you can get 25% more sunlight than flat laying, which is the best choice for recharging your ROCKPALS power station on-the-go. Folded Dimensions: 17.32*14.57*2.17 in, Unfolded Dimensions: 68.11*17.32*1.18 in.
[WATER-RESISTANT & DURABLE] Made from durable Oxford cloth. The solar panel surface is IPX4 waterproof, but do not recommend to use in the rain or fall into the water.
