I have a pre-LFP Xantrex XW6048 with a Midnight Classic 150 charge controller. This is configured with 4-12 Volt gel batteries which I would like to replace. I'm looking at 2-48V Lifepower EG4 V2 batteries in parallel (200 total Ah). I'm not looking for a closed loop communication with the batteries. I would be interested in anyone who has accomplished this or similar and in particular what settings they have used for the inverter and charge controller. I have scoured this and other forums and here's what I've come up with as tentative settings:
Xantrex inverter settings: Suggested LFP values
Low battery cut out 48V
LBCO Delay 30s
High battery cut out 70V
Search Watts 50W
search delay 2S
Xantrex charger settings:
Battery type custom
eqlz support disabled
Bulk, absorb, float 56.8V, 56.8V, 54V
batt temp comp 0
battery capacity 200 AH
Max charge rate 55%
charge cycle two stage no float
recharge volts 50V
absorb time 0:02min
Classic and whizbang jr
Battery capacity temp comp 0%
temperature comp As low as possible
EQ ABSORB FLOAT limits 56.8V 56.8V 54V
input/output max current 100/100A
ABSORB EQ time 0:00
ending amps 0A
Any help is appreciated.
LBCO Delay 30s
Search Watts 50W
search delay 2S
Battery type custom
batt temp comp 0
Max charge rate 55%
recharge volts 50V
absorb time 0:02min
ABSORB EQ time 0:00
ending amps 0A
