Hi-new eve 280 cells (8s) - first time charging in series to save time for top balancing. when the charger is on, the app always indicates one cell in red, -higher voltage by up to 60mv, but it's a different cell after i pause the charging and restart it (although usually one of two cells only). when i turn off the charger, all 8 are within 2 mv of each other. when i turn the charger back on the app will light up one cell. now that the voltage is over 3.4 on that cell, it is being "balanced". is it normal that they are very close with the charger off and instantly farther apart with the charger on?? it seems they were top balanced by the seller already (right?, assuming they stay as close as they are over 3.4v, or is it really 3.5v to see a difference??) i'm using the android version 3.1.1026
