XT60 + 5.5x2.1mm Connection to Portable Battery Station
Windnsalsa
Summary: Possible & safe to connect an XT60 [on 1 end] -- 5.5x2.1 mm barrel [on other end] connection to a 300Wh portable solar "generator"?
Similar to Will's video of XT60 replacing mc4 on the 60w panel and Jackery 240 included mc4 cable, I want to do the same. But, the Jackery 240 included an mc4--8mm barrel cable, and my Golabs' is an mc4--5.5x2.1mm barrel. The jackery's 42W Max input with 12V~30V . I am not sure about the 2.1mm connector, but the Golab's 65v max input & MPPT controller supports voltage is 10.8-23.5V (3A).
Would I be able to cut wire with 2.1mm barrel attached from a standard 20v laptop power brick and attached an xt60 connector to the cut end? I have many power bricks. I can also cut the mc4 connector from the 2.1mm cable that came with the Golabs as well if need be. Amazon has lots of xt60--2.1mm FEMALE [not male] barrel cables. Though there are a few cables with the male barrel on ebay & one on Amazon. I don't know what the green block on that male barrel is...screw block?
I am wondering if there's any concern electrically? I did come accross someone mentioning barrel connection from power bricks are regulated or something like that.
Also, with the max 3a input, when a 100w panel [usually 5-6a] is connected, is the mppt limiting the amp to 3a?
THANKS!
-------------links:
Will's video: DIY Jackery 240 Solar Panel: Save $250!! Beginner tutorial 35,950 views •Feb 9, 2019
Jackery 240
Golabs r300
5.5 x 2.1mm Male Barrel to RC XT60 Female Adapter
Windnsalsa
Summary: I did much research, but my research probably sucked! Possible & safe to connect an XT60 [on 1 end] -- 5.5x2.1 mm barrel [on other end] connection to a 300Wh portable solar "generator"?
THANKS!
-------------links:
Jackery 240
Golabs r300
moomoo
I am going to end up doing the same thing using an xt60 female to 12v barrel male. Did you end up getting yours to work?
