Title says it. I just installed an XW6848 Pro in a solar / backup system. Unit was purchased new in June. When in grid support it works fine, but when it goes to battery backup (invert) the cycles will jump to 70hz. I can hear the change in a fan nearby and the inverter itself, so its not just a false reading. When the grid comes back on it sync's properly and reconnects. This is day one of this inverter being installed. Firmware was updated to latest available on 7/3/22. I have contacted support and waiting to hear back, but wondering if there is something I have wrong in the settings. I have an SCP and Conext available. I have gone through the entire advanced config on the Conext and didn't see anything I thought would affect this. This inverter is 1 of 4 we are installing at this location. This unit will be a stand alone unit (only shares the battery bank).
The battery bank is a custom modified Tesla Lithium-ion, 16 cells in series x 6 parallel, 80kw, input voltage can range from 48 to 64. One thought was the inverter might be trying to do frequency shift because the battery voltage is high? I have all the charge set points at 64V. My older XW6848+ worked fine on this pack.
