I'll do some averaging here for you, because I don't have a watt meter on the single appliance.Any idea how many watts it uses over a 24 hour period ... when in temps between 83F - 94F over the 24 hour period and the AC temp set at 73F.
I agree with you. It's working great in my C at 25'. True. Also true I have zero shade. No awning, no trees, nothing. Sitting on the lane black top all day in the sun. So far so go, I'll keep an eye on it. Very happy so far, but if nothing else, it's certainly possible, and with some tuning to your own rig and demands, it could be replicated successfully.I think the numbers you gave are good for a 25’ class c.
In temps you mentioned, I am parked in the sun and my AC will not cycle off until the sunsets so my power usage would be greater.
Whether in the shade, amount of insulation, and how much you open the door.
This thread has gotten me thinking if it’s possible for my situation with about 400 - 600 AH of lithium batteries at 24 volts. I already have 1350 watts of panels, Going to spend some time thinking what I need to complete this.
Can you clarify the Amperage draw numbers? You show 25a for am hour or 25ah. When converting 120v AC to 12v DC 25a of DC is around 2.5a of AC. Is the unit drawing that little power?I'll do some averaging here for you, because I don't have a watt meter on the single appliance.
If I'm using 25a when it's running maintenance, and in the ON state, making cold, ON cycle. Let's average that run activity for 10 hours,
-Runs 25a for one hour, that's 25ah, x 10 hours, that's 250ah, 3350w total consumed.
and then let's assume it's slightly less during non-sun hours, and it runs a bunch overnight.. on and off, but generally still cooling most of the time, so...
-at night it runs 20a draw for another 10 hours, 20ah x 10hr is 200ah, 2680w consumed overnight.
Let's add this all up, and then make some guesses:
-Day use 250ah, 3350w.
-Night use 200ah, 2680w.
Now lets add in some reality.. .I DO in fact know that most I've ever consumed in power over night at this temp range is around 100 ah after the solar stopped.. so that's my total load, but let's assume it's mostly AC. Then, let's also admit that the unit doesn't run ALL THE TIME during the day, it's cycling on and off, so we will discount that load number as well...
-(Day use 250ah, 3350w.) if it runs 80% of the time, that's now 200ah, 2680w used during the day.
-(Night use 200ah, 2680w.) considering I've only seen half this usage, let's cut this in half. 100ah, 1340w night use.
Now we have a realistic estimate... We are burning up 4020w of power to run this setup over 24hrs at your temp range of "between 83F - 94F over the 24 hour period and the AC temp set at 73F."
Let's also assume I can generate 800w per hour on solar. And assume I'm going to eat the ENTIRE system load of the AC, 4020w using solar. IF this is true, here's the math:
-4020w / 800w = 5.025 hours of 800w production from the solar per 24hr period to satisfy the AC load.
This also has some other interesting notes... now that we're down this trail this far.. our load math has asked us for 300ah of battery to eat this AC load for a 24hr period. Let's assume you don't charge at ALL in that period, you're going to consume 300ah of battery to keep that load running. I do believe this is realistic, considering my actual numbers in my unit and my experience with it.
This would lead be to have storage well beyond this 300ah capacity, and I do have 550ah of lithium on hand.
I hope this helps
Chris
Yes sir. I started this project for the same reasons, and I'm very glad I did.This is inspiring me to get rid of my overhead a/c unit, which does the job but is loud, the fan always blows at a high speed (even when set on low) and requires shore power or my generator to run it. The key is these inverter mini-splits that have high SEERs...they are so efficient and they have a variable fan speed.
I've begun my research, thank you for the inspiration!Yes sir. I started this project for the same reasons, and I'm very glad I did.
I would love your input!Excellent thought and planning here. I'm going to take a day and see all your links, so I can reply with sense.
The mini splits don't have to push air through the inefficient ceiling ductwork. That likely adds 20% to the load of the RV.This is inspiring me to get rid of my overhead a/c unit, which does the job but is loud, the fan always blows at a high speed (even when set on low) and requires shore power or my generator to run it. The key is these inverter mini-splits that have high SEERs...they are so efficient and they have a variable fan speed.
Input incomingI would love your input!
After over two hours of searching, I think the next step is to contact Senville and ask if they recommend against mounting their unit on the ceiling. I just can't seem to find a suspended ceiling unit at the BTU/price point I'm looking for. I suppose I could possibly spring for the Pioneer if the Senville is just too thick or can't be mounted on the ceiling. Solar panel costs have come down so much that the money I would have spent on them can go into this device.
I wonder what the feedback will be once there's more of these mini splits popping up on RVs. I do worry about a bumper mount if I install one. Those bumpers do bounce a lot.Basic answer is "they are not for mobile use"
