hgg
- Sep 5, 2022
- 73
Hi,
I am building a DIY Yixiang battery box with 16 MB31 cells and the JK 16S 200A BMS.
The issue is that I can measure voltage from the chassis to each cell. The voltage
is not stable, its like a phantom voltage and when I measure it with low-Z, it shows
a much smaller value. I've turned it on and it works, but I would not like to use the
battery case like that.
It seems like there is a conductive path from the JK BMS to the chassis.
Did anybody else had a similar issue?
Thanks!
Thanks!
