AmyG
If you can remove the headliner, won't you be able to see where the aluminum frame is? If so, then at least some of your brackets could be attached with through bolts to the frame.
This concept was what led to the idea of putting aluminum backer plates on the back of the fiberglass overcab because the backer plates would move with the fiberglass as it flexed.
the Fiberglass cap of my RV is like 2mm thick - it's very bendy. I wouldn't trust that stuff.Nope, nope, nope. PV panels mounted only into the fiberglass is not going to end well.
I plan to use unistrut and lift the strut every few studs, at least a few inches. either buy "feet" from unistrut or just get some1 by 2 aluminum tubing, cut it a few inches long, and and drill a hole to do the lifting. BTW, where did you find the fitting to use with the unistrut?With Unistrut:
1. You choose where the fasteners go
2. It's a heck of a lot easier than Z brackets
3. It's more flexible should you decide to go with larger/smaller panels
4. It's way easier to remove a panel from the room
The one reservation I have with the Unistrut is that it may mess with the drainage pattern on a roof.
I just used the strut nuts and right sized bolts through my solar panel z-bracketsThe PV mounting brackets that work with unistrut? I don't have unistrut in my system yet, so I haven't sourced those type of brackets.
I’d still bolt it.The 5200 alone will hold more than you need
True. I wasn't implying using ONLY 5200 but it sure looks like I did, now that you mention it.I’d still bolt it.
I use polyurethane caulking as a structural adhesive very very often but never by itself- always a fastener plus the polyurethane
