Thanks for you reply Horsefly and the charger I have says it is a EBC-A40L and I do not have a shorted cell I have since purchased a second charger just like this one and it has been working perfectly. All cells have been charged to 3.5v and then top balanced to 3.65 v. I am now in the process of testing these massive cells. I am on the 7th cell so far and the second charger is working perfectly. The first charger has a issue and I'm just looking for someone that can help me get it repaired or replaced. As you know these chargers are not cheap knock offs.I assume you mean the ECB-A40L (vs the EBC-A40L you said). I have the ECB-A40L and it has worked fine for me. Have you checked the cell (the 11th one) to make sure it is not shorted or dead? I'm not sure why it would go to 71A.
I don't really have any suggestion, but I will say that I had a problem with a cheap benchtop power supply that I bought on Amazon but was from China. Amazon wouldn't do anything but said I should work with the seller. I tried several times to contact them like you did, and after a couple of weeks I gave up and bought a new power supply. Then out of the blue another 2-3 weeks later they contacted me and said that based on what I reported it sounded like the power supply failed, so they shipped me a new one. They didn't want the blown one back. My only point is that maybe it takes a while to get through their system and have take note.
Oh and by the way, I'd prefer if your post wasn't in bold and large font. Not a huge issue, but I almost decided not to read it.
Did you eventually get closure on this?. the ebc a40l charger has stopped powering on, need help in resolving itThanks for you reply Horsefly and the charger I have says it is a EBC-A40L and I do not have a shorted cell I have since purchased a second charger just like this one and it has been working perfectly. All cells have been charged to 3.5v and then top balanced to 3.65 v. I am now in the process of testing these massive cells. I am on the 7th cell so far and the second charger is working perfectly. The first charger has a issue and I'm just looking for someone that can help me get it repaired or replaced. As you know these chargers are not cheap knock offs.
I never got any help on the bad charger I just put it back in the box and put it awayDid you eventually get closure on this?. the ebc a40l charger has stopped powering on, need help in resolving it
Do you plan to sell it as is?I never got any help on the bad charger I just put it back in the box and put it away
I might consider itDo you plan to sell it as is?
It has a dual voltage switch underneath.Get an appropriate plug or adaptor, then shidt the switch to 120v and you would be goodWrong Model ZKETECK EBC49L. I just received my long awaited tester from China and it arrived with the wrong power cord (plug) and the plug says 230v, 10amp. Does anyone know what power may be acceptable, i.e. 120v, 60hz? In other works do I just need a proper plug or is there a different power supply in the tester for North America?
Its the EBC-A40L. Not the EBC40L not the ECBWrong Model ZKETECK EBC40L. I just received my long awaited tester from China and it arrived with the wrong power cord (plug) and the plug says 230v, 10amp. Does anyone know what power may be acceptable, i.e. 120v, 60hz? In other works do I just need a proper plug or is there a different power supply in the tester for North America?
Hello,Does anyone want to help the development of the MegaCellMonitor with the EBC-A40L? Currently the MegaCellMonitor support EBC-A20 and EBC-X chargers of ZkeTech.
What is needed?
1. Laptop connected to the EBC-A40L
2. Serial to Ethernet software (which i can provide)
3. 1 or 2 weeks of development time with access to the laptop for debugging purposes.
Contact me if you are willing to help in adding this charger to McC.
Hey just curious what those testers are, the fleabay links have expired. I found the first one, I guess we'll just call it the HeltecBMS tester? What was the other one, the first one of the two above? The text seems to be about the old EBC-A40L but when you put the now-expired link in you said whatever it linked to also dod 50A.Its the EBC-A40L. Not the EBC40L not the ECB
EBC-A40L
Interesting to me that the inside of it contains a 60A power supply yet the charge is limited to 40A (manual says 35A but that might be the prefer derated current)? I own the EBC-A20 (kind of wish I had gone with the EBD-A20H)
EBC means the charger has an onboard charger OR in the case of the the EBC-B20H it allows an external charger to be connected.
EBD means it is a discharge only unit.
I'm not quite sure what to make of the letters used but I do know that the number is usually indicative of the current rating for discharge but keep in mind there is also a watt limit. The EBC-A20 has an 85W limit whereas the EBD-A20H has a 200W limit but it does mention running it at no more than 90% of its wattage rating so 180W. The EBC-A40L has a 40A discharge current with a 40A charge current but like I said the manual does says 35A.
There are now a couple other options available
50A charge and discharge
EBC-A40L large single current lithium iron battery capacity tester 5V40A50A | eBay
Find many great new & used options and get the best deals for EBC-A40L large single current lithium iron battery capacity tester 5V40A50A at the best online prices at eBay! Free shipping for many products!www.ebay.com
50A 220V Li-ion LiFePo4 Lithium Power Battery Capacity Tester Charge Balanced * | eBay
Find many great new & used options and get the best deals for 50A 220V Li-ion LiFePo4 Lithium Power Battery Capacity Tester Charge Balanced * at the best online prices at eBay! Free shipping for many products!www.ebay.com
