GXMnow
Solar Wizard
- Jul 17, 2020
- 2,748
While looking at the Enphase logs with my breaker trip, I saw something I neve did before.
This is the very end of the logs after grid was restored and everything was going back to normal. All 16 inverters reported all of the clear messages for AC frequency high and low, Grid Instability etc. But the last 2 entries caught my eye.
"AGF Profile CA Rule21 201902 VV VW FW/01.02.08.00 deactivation okay"
I am assuming it detected it was off grid and switched to an off grid mode of operation, so it stopped using the Rule 21 profile. But it is odd the deactivate and then reactivate posted in the same minute.
Earlier in the logs, I found the exact point I messed up. As the power to the Envoy was lost at the same moment, it was not able to log the actual power fail events. But it did log the system starting back up while the XW was running in off grid mode. At 11:33 am it has this message.
"translation missing: en.env_enl_api.event_type.emu.lvrt_ac_loss_event"
Then all 16 inverters report "Grid Instability" "AC Voltage Low" "DC Power Low" "AC Frequency High" AND "AC Frequency Low".
I like this one
"AC Voltage Out Of Range - Phase 1: Set"
I never see a "Phase 2" but it looks like they newer firmware takes multiple steps to try and recover from grid issues. I have to say, the system handled this situation very well.
Had I fully understood what happened, I would have taken a bit more time and recorded more data before getting it back on grid. I only had about 100 watts running from grid, all the main loads in my house were running just fine off grid, except of course I crashed 2 PCs and my Dish Network DVR had to reboot and reacquire the signals. My router and internet came back up pretty fast, even as it was running off grid.
In the Enphase logs, the grid loss was at 11:31 and it looks like I restored the grid power connection at 11:49 am. The time in the Schneider Gateway is showing 2 minutes faster, so that would be 11:33 and 11:51 am.
At 11:33 the XW goes to pulling 10 amps from the battery to power the 600 watts of loads in the house on the backup panel. But then it swings to charging at 20 amps as the Enphase inverters start producing power into the backup panel at 11:34 much earlier than 5 minutes. So this must be an off grid mode. But again, my battery was full. So the next minute, the charge current is down to 10 amps for 2 minutes. Then the current ramps down, through zero and over the next 4 minutes, it settles in at 10 amps of discharge again, running the backup loads with no help from the Enphase system. I must assume this is when the frequency went high enough for them to just stop making power completely. This holds steady for 11 minutes to 11:51 when I turned the grid side breaker back on. The XW saw the grid return, so it did what it always does and went back into charge mode at the 35 amps set by my PLC. But the battery voltage was still high enough, it went back into No Float after 3 minutes.
From 11:56 all the way to 6:32 pm, the XW-Pro just sat in Pass Through again with the Enphase back powering the house and exporting all it's excess. From 6:32 until 7:11 the solar dropped off and the XW ramped up from battery to cover the loads. All as it should work again.
At 7:11 PM all the Enphase inverters started reporting DC Power Too Low as the sun goes down behind the palm trees. So it's running on battery until sunrise tomorrow.
And even with the Enphase system being shut off for a bit and tanking the production for 20 minutes, it still produced 30 KWHs for the day. That is the first 30 all year. The Victron only did a bit over 8 KWHs as it had to go into float with the battery being full so quickly, even after the bad production yesterday.
Here are the traces for the full day.
Enphase
XW
I tried to line up the time, it's pretty obvious where it fits.
I like this one
Enphase
XW
