flinx777
- Sep 14, 2022
- 9
We've had issues recently with our power grid going down from time to time. We've lost food in our refrigerator on too many occassions and I'm looking to build the most basic, affordable, barebones battery/inverter/charge controller/solar panel setup. I've watched enough of Will's video to understand how to build a basic setup, but what I'd love to know from the community is what is the recommended, most affordable parts or kit to build out your own solar setup.
Here are the key points as I understand it:
Thanks in advance to a very knowledgeable community!
- 1.5 kWh power drawn each 24 hours by the refrigerator (I purchased a kill a watt meter to record the information).
- 82% efficiency of AC output on a typical inverter (inverters are not 100% efficient).
- 300 watts of panels at 75% efficiency in a typical environment (I live in a very sunny area) pointed at the sun (I'd have to move the panels throughout the day).
- Maybe 10 hours of usable sunlight to charge the batteries, may be 4 to 6 of those hours providing peak power. Obviously, the fall is here and winter will be around the corner and there will be less sunlight.
- I think a 100 Ah battery would be the bare minimum (1.2 kWh) needed.
- I've looked at various charge controllers, but not sure what the best would be for this setup.
- 2, probably 3, 100 watt panels.
- 1000 watt inverter should be enough I'm assuming.
