Seems like getting a spare BMS and shielding that would be the easiest.Is there anything to be done that will minimize risk?
Have you researched threads here on diysolarforum regarding this? Are you concerned about humans setting one off or the sun putting it to us?
Protecting a battery that is connected to devices/electronics would be extremely difficult to protect. Even if you could protect a battery, it would likely be cost prohibitive, especially when compared to what a spare BMS would cost.
And having a spare BMS on hand is always a good thing anyway.
You could always use Lead acid.I did a brief search on the forum and with the Duck search engine. No luck on anything yet.
My source of worry is three-fold:
1) US fedgov crosses every red-line they encounter in Ukraine and appears to be trying to start an NBC exchange with Russia.
2) We are in the process of a pole-flip and (my belief) a micro nova. Persuasive people in-the-know say the 12,000 year cycles are the worst and we are at the end of one of those 12K cycles now. It's not a question of "if" it will happen .... the question is "when".
3) My other gear is "EMP hardened" and assuming the protection works -- that makes my battery pack the weak link. A blow out here means no storage.
I think so. More than electronics by quite a bit anyway.Do you think the physical lithium batteries are immune to an EMP?
Guaranteed to survive zombie apocalypse or Crazy Leaders.
EMP is really only a concern for long wire runs.
Hard to say. For sun based EMP they are long amplitude waves so very long wire runs needed to have an impact. Nuke based EMP has a full frequency spectrum so shorter wires could get a V spike but not a lot of amps. I doubt it would burn any medium/high power circuits but IC/CPUs could be destroyed if they are in the surge path.Any sense of what constitutes a long wire run? Hundreds of feet, or thousands of feet?
