I hooked mine back up but I think ones of those is the interlock.I have a Ryobi ZT540e.
I swapped the OEM batteries for the CHINS battery last night and charged it up overnight.
Do I ahve to install both of these for the ZT540e to work?
Can I bypass them?
I have the same mower and installed a CHINS battery. I hooked those parts back up, don't know if it was necessary or not, but I pretty much left everything like it was. The new charger has its own port connected to the battery. Works fine.I have a Ryobi ZT540e.
Can I bypass them?
Must have been some thick grass or something.Is anyone interested in my conversion from SLA to 304Ah Expert Power cells from Amazon? I have Pictures. First mow of 1.66 acres and only used 18% or 53.31 Ah.
Looks nice..Also had to make a new battery tray hold-down. Had to get some metric threaded bar too. I put 1/16th inch thick rubber sheets on top for my bumpy yard. So the batteries wouldn't contact the frame in any way. And it all JUST fits.
No just the pack and a Cycle Satiator charger from Ebikes.ca oh and an Overkill BMS. It all seems to work good. There is no more bogging down on some of my hills that used to bog me down when climbing them to Now.Looks nice..
How do you like it so far?
Are you using a pre charge resistor?
Yea I have noticed the same things.No just the pack and a Cycle Satiator charger from Ebikes.ca oh and an Overkill BMS. It all seems to work good. There is no more bogging down on some of my hills that used to bog me down when climbing them to Now.
You can get to the power button on the vatrer from underneath - you can see the openings on the battery tray now that the vatrer is shorter than 4 AGMs. It says to turn it off if not using for more than 5 days. I’d assume it’s good practice to follow.Thanks just assembled it up exactly as it was (minus the original thermistor cable off positive) and it functionally seems to work as expected! Hoping this week I can give it a good run once I figure out mounting.
I too am wondering about this on off button. I’m assuming/hoping it can just stay on…
Nicely done.Some more photos
Unfortunate update. I plugged the HTRC charger at 5 amps, it charged for a couple hours. I decided to up it to the "13 amp" setting. It only pushed out 9.5 amps for about 30 minutes and the charger put out the infamous magic smoke and the back plastic melted on it. Batteries appear to be ok though.Nicely done.
Looks very similar to mine.
Just used Kapton tape also.
No problems so far..
