I think Sol-Ark is the only one offering a full EMP system that has been tested.Is it worth it? I guess that comes down to how many nuclear attacks or Carrington events you plan on withstanding.
Put your money into lightning protection, IMO.
It is not as simple as that.Just put spare solar equipment in a grounded Metal shipping container.
I said spare. That would be replacement equipment if the other equipment failed from EMP, etc.It is not as simple as that.
The PV wiring is going to be a major energy absorber of an EMP.
That is why Sol-Ark has special MPPT's on the EMP version and also a Box full of Chokes for every part of the wiring.
I agree here..lightning itself is a form of emp discharge of you can withstand 300 miillion volts and as much as 30 thousand amps then your good. Yeah its totally worth it in my opinion but that's a direct hit. I once had a tree outside my house get hit the bolt jumped from the tree into my heat pump knocked a lighted antique crystal budweiser clock off the wall damaging the lighting circuit destroyed several vcr units and burned up the motor in a 20 foot fiberglass satellite dish. Several years later the tree grew back and was struck again but it being much smaller dissipated to the ground around it thank the heavens above, but the transients still burned up the replacement motor in the satellite dish..by that time we had bought a hand crank apparatus to be able to reposition the dish..big hassle expensive homeowners insurance claim not that we had to pay for any of it accept for time and white knuckles hair pulling on the phone with the adjuster...yeah emp hardening is worth it. But it doesn't have to be a big Faraday cage nessecarily. Although that will improve your chances of survival much much better. Look intol arge metal Oxide varistors and and transient voltage suppression diodes and build one yourself although it's not just as simple as these two pieces but this is at least a start...good luck and stay safe...Is it worth it? I guess that comes down to how many nuclear attacks or Carrington events you plan on withstanding.
I was told the MPPTs are different. I think some of the other boards are also different.I have a EMP hardened Solark. From what I have seen the hardening is circular magnets around Wires inside. 2 magnets around the Battery cables and magnets around each solar panel.
Do you utilize any surge or lightning or emp protection on either your solar or HAM system? If so, what products have you found worthwhile when considering cost, magnitude of potential damage, scale of potential outage or attackLightning protection and EMP protection are entirely different things.
I am one of those Ham Radio guys (VK3ALY).
I have also professionally been involved with designing lightning protection for multi million dollar projects.
