I have a stack of 6 EG4 LifePower4 batteries in a cabinet from Signature Solar like the pic below
the middle 4 batteries are fairly well in sync, usually +/- 5%, but the top one could be lagging by 20% and the bottom up to 40%
this causes problems when the bottom battery falls below 15% and I need to switch from solar/battery/grid -> solar/grid/battery while I still have 50% + in the middle batteries. My connections are all solid and I have my inverter connections at opposite ends of the busbars to help spread the load.
I have thought of perhaps adding relays to each battery so I can disconnect them when they fall below 15% or above 95%
Is there a better solution out there?
