Cabin Rising
My small humble cabin in the woods is just about ready to be tied to the grid. Arrangements have been made with local co-op. Just waiting in line to get connected. My new service will be completely buried underground and out of the way. No trees requiring to be cut down or any land cleared out. Just soon as they set the meter, I will hopefully have all of my wire run underground ready to connect up.
I have a very modest solar array that has been working well for the last four years. It consists of 180ah 48 volt battery bank fed from 1800 watts of panels wired to work with a 30amp charge controller. Last week I picked up more panels that will add 3000 watts to my system. Then whatever else needed to connect everything. Just thinking things thru and trying to piece it together that will help out the overhead. I was considering a grid-tie or more likely a hybrid connection.
From my co-op:
All of my equipment is 3 phase, so a rotary converter is something else I have to work on. The shop is not something that is going to be used all of the time, so big power demands spinning the meter to an early death spiral is not likely.
Am I over simplifying all of this or missing something?
From my co-op:
- We will inspect to ensure a properly working UL 1741-compliant inverter. Requirements include:
- A visible, lockable, and accessible solar A/C disconnect switch.
- A label/notice indicating the presence of solar energy.
