Dave12111964
Hello Everyone, I have a question regarding power clipping.
I have 2 DEYE 5KW inverters in my property in Philippines working in a Master / Slave operation. The system can be considered to be 10KW so I believe I should have that power available when all panels are generating to their full capacity (Give or take for losses0
I have 4 solar arrays
2 arrays for each inverter.
I have 2 lithium batteries, one of these is 200AH and is connected to the master, the second battery is 228AH and connected to the Slave. They are connected in parallel to the inverters and linked together with a comms cable
The panels are Trina Solar I2, Pmax 460 W.
I have 7 panels on the Master inverter string 1 and 6 panels on the Master inverter string 2 meaning the master inverter is served by 13 panels X 460 = 5980 Watts. I think this is too much.
I have 7 panels on the Slave inverter string 1 and 6 panels on the Slave inverter string 2 meaning the Slave inverter is served by 13 panels X 460 = 5980 Watts. I think this is too much.
I use "zero export to CT" with solar sell enabled. The energy pattern is "load first"
The system is in the Philippines, the sun shine is pretty reliable most days from 06:00 am to 18:00 pm
This system suffers from "power clipping" I have attached a screen shot from the 17th June which appears to be a classic example of power clipping
The only time this does not happen is if I allow the battery to discharge during the night. Once the sun appears the system charges the battery and will generate up to 9.8 KW during the charging process. As soon as the battery SOC reaches its set point the PV power is once again reduced to below 5KW
Does anyone know why this happens? Why can I not generate up to 9KW of power from the system during a normal day ? I am considering reducing the amount of solar panels to 11 per inverter to bring to array power more in line with the inverter to see if this helps.
Any advise would be most appreciated
Thanks
Dave Jobes
Thanks
Dave Jobes
