zanydroid
Solar Wizard
Probably a basic arithmetic brain fart. I think 120kwhI was following along nicely until that one.. what planet do you live on?
Now I'm farting along with him.. questioning my own sanity.Probably a basic arithmetic brain fart. I think 120kwh
YesProbably a basic arithmetic brain fart. I think 120kwh
For grid assist double conversion doesn’t seem to make sense to me, you would probably need something smarter than just hooking up a Chargeverter. Which might just end up costing more than a grid tie hybrid
Backup is the only use I have for the grid.OK, yup that makes sense.
But it wasn’t clear to me if the OP was interested in grid assist to boost the capacity of the inverter and battery or just having grid there to back things up if the battery or solar runs dry, without risking problems with POCO.
For grid as backup your system works well.
It won't.Back feed hahaha I'm wondering how will mine ever knowView attachment 223983
Your probably a good person to ask Tim but are they ratcheting? Hypothetically of course when setting up my on-grid/hybrid I'm likely going to commission it then have them inspect post install if I did back feed would the meter run in reverse? Getting caught reversing the meter here is probably a big offence especially for foreigners I wouldn't want to anger the utility supplier as it's a government entity.It won't.
I just lost my dumb meter, a few months ago.
It's just a motor spinning that disc. The motor is powered by the current that flows through the meter. Most are not directional, but some are.Your probably a good person to ask Tim but are they ratcheting? Hypothetically of course when setting up my on-grid/hybrid I'm likely going to commission it then have them inspect post install if I did back feed would the meter run in reverse? Getting caught reversing the meter here is probably a big offence especially for foreigners I wouldn't want to anger the utility supplier as it's a government entity.
P.S.It's just a motor spinning that disc. The motor is powered by the current that flows through the meter. Most are not directional, but some are.
A person would have to actually see it spinning backwards to know.
They regularly visually check the meters here so I'll try to commission my system right after an inspection to play it safe, cheers for the info.It's just a motor spinning that disc. The motor is powered by the current that flows through the meter. Most are not directional, but some are.
I don't plan to export anything untill I have the system all finished and we book an appointment for the Poco to inspect, I guess then they will swap us out for a digital meter.P.S.
If it's not directional, you will be charged for both import and export.
As it will not know the difference.
You guys lost me in all of this discussion, but I'm interested in a grid assist more than a grid backup. I'm only planning on having a few solar panels and a small-ish size battery so I want to maintain some amount of assistance from the grid as necessary without having a switch going back and forth. It may be too much to bite off, but I may just be overthinking it. The information and specs provided doesn't make it easy to figure out what is going to work for me.it wasn’t clear to me if the OP was interested in grid assist to boost the capacity of the inverter and battery or just having grid there to back things up if the battery or solar runs dry, without risking problems with POCO.
Sorry let me see if I can help, from what I understand you would want a off-grid/hybrid this shouldn't back feed and has a built in ATS so it would only pull from the grid when solar doesn't produce enough to satisfy your demandsYou guys lost me in all of this discussion, but I'm interested in a grid assist more than a grid backup. I'm only planning on having a few solar panels and a small-ish size battery so I want to maintain some amount of assistance from the grid as necessary without having a switch going back and forth. It may be too much to bite off, but I may just be overthinking it. The information and specs provided doesn't make it easy to figure out what is going to work for me.
Wrong terminology.Sorry let me see if I can help, from what I understand you would want a off-grid/hybrid this shouldn't back feed and has a built in ATS so it would only pull from the grid when solar doesn't produce enough to satisfy your demands
Also, I'm not aware of an active forum member from the Bay Area that has a micro-scale system. There's some availability / survivorship bias in this, in that people who stick around to talk about/level up in the hobby escalate their projects in scale.You guys lost me in all of this discussion, but I'm interested in a grid assist more than a grid backup. I'm only planning on having a few solar panels and a small-ish size battery so I want to maintain some amount of assistance from the grid as necessary without having a switch going back and forth. It may be too much to bite off, but I may just be overthinking it. The information and specs provided doesn't make it easy to figure out what is going to work for me.
Here we have both on-grid/hybrid and off-grid hybrid on grid being grid tied but has a battery, off-grid/hybrid being one that's off-grid but can import grid power not export it.Wrong terminology.
Grid-tied
Requires the grid to function. And sends all production to the grid, or directly to the loads. (Can export)
Off grid
Doesn't require the grid to function. Sends all production to a battery, or directly to the loads. (Can't export)
Hybrid
A combination of both above. (Can export)
The term "hybrid" means that it can function as both grid-tied and off grid.Here we have both on-grid/hybrid and off-grid hybrid on grid being grid tied but has a battery, off-grid/hybrid being one that's off-grid but can import grid power not export it.
From my pov and the terminology used in Thailand/China and off-grid hybrid perfectly suits his needs I use one as a ups for our fridge, sever rack and lights. When solar is producing it will take that as a primary input if the load is greater than production it compensates with grid power if there's no grid or solar it draws from a battery.
I'm not using the term SRNE is and after looking it seems there's no 120v versions so that's likely why you've never heard the term off-grid/hybrid they aren't available in the US.The term "hybrid" means that it can function as both grid-tied and off grid.
What are you using the word "hybrid" to describe?
That's a very confusing advertisement.I'm not using the term SRNE is
vendors tend to say anything for a sale. Whether it's correct or not.
