madscience
- Aug 1, 2020
- 1
Where in my system should I place a shut off. I am building a small 400 Watt system on a house boat and want to turn it off after weekend use. It can harm solar charge controllers to have power from panels hooked up with out battery connected correct? So having a disconnect for batteries is not a good idea? Do I wire shut off at input before solar enters controller? I can simply turn off inverter at back of unit switch and lights have built in switch, only other load is toilet.
Just would be strange to have no shut off, is that standard?
Thanks, First post...
