BronteJane
I know this topic has been discussed on other threads but I am still struggling to find specifics. I am setting up an entirely off-grid system with the exact same architecture as the system map below. My question is where do I create the Neutral - Ground bond in the system? Based on my research, it seems like it should be located at the load center (breaker box). If yes, do I simply run a grounding rod from that ground point? Also what grounding setting should I set the EG4 to once that is established (ie setting option, #26)? Thanks for any help, much appreciated.
