Red Squirrel
- Jan 1, 2020
- 110
Curious what everyone does for low voltage disconnect on your systems, in order to preserve the batteries. My train of thought is to mod the inverter so it can be turned on/off via a relay (by modifying the on/off switch which is usually a soft switch) and then having a microcontroller that monitors the battery voltage. Could also make it monitor the solar voltage so that when it does turn off, it will only turn back on when it sees solar voltage (in case the battery voltage creeps back up naturally).
But wondering if there are solutions already for this that I just don't know about?
