Paul.Barrette
- Nov 23, 2019
- 39
Hi everyone... I built this small system for a mobile barn I have on my property. I know it's overkill for what I need to do but I wanted to learn by building something that has all the various components of an off-grid system.
Here is a photo of the entire system... I want to add a temperature sensor latter on
![B8F86224-55FF-418A-923D-BF83ED4A8679.jpeg B8F86224-55FF-418A-923D-BF83ED4A8679.jpeg](https://diysolarforum.com/data/attachments/2/2515-2e5331902fb083d46d444eca553a61c6.jpg)
Is the wiring correct? Everything powers on but I have not found any examples on Will's site that uses the fuse box for the inverter... All examples I have seen have dedicated fuses... Is this still OK?
The Charge controller is a 20 AMP model...
![C634B4A6-0A1D-4588-91FE-E961249B1D8B_1_105_c.jpeg C634B4A6-0A1D-4588-91FE-E961249B1D8B_1_105_c.jpeg](https://diysolarforum.com/data/attachments/2/2516-8f044d6f3fdaec32e32e4760cb2bb0ba.jpg)
...and the inverter (i know it's a cheap unit but it was given to me and a don't really need AC) is rated to support 15 AMPS max
![38408390-E75B-4A32-80A5-F770326BF3C0_1_105_c.jpeg 38408390-E75B-4A32-80A5-F770326BF3C0_1_105_c.jpeg](https://diysolarforum.com/data/attachments/2/2517-87002833c9b95fb5fde1b8fdedeb5085.jpg)
I am using 4 old Panasonic prismatic cels (From a Nissan Leaf I think)... I got them for pretty cheap. They are used. I do not have a lot of details on them. Here are the specs I found:
Cell specification :
Battery type : Lithium-Ion
Nominal voltage: 3.7 V
Operating voltage range:
Minimum : 3.0V
Maximum : 4.2V
Length: 5.875" (148 mm)
Width: 1" (26 mm)
Height: 4,5"(over terminals) (113 mm)
Mass: 1.65 pounds (0,72 kg)
Any additional details that you can provide here are welcome.
I am having difficulty setting up the MT50 configuration... I know I will not get the full 25 AH because of the weird voltage. If anyone can help providing the optimal configuration I need to input... It would be appreciated
![86CF29AC-1D70-4E30-AE25-27B6E9F43B91_1_105_c.jpeg 86CF29AC-1D70-4E30-AE25-27B6E9F43B91_1_105_c.jpeg](https://diysolarforum.com/data/attachments/2/2518-2aa189fdac46e2cd37d4b8232a8eb7a1.jpg)
![D8C09078-B630-4C7E-94B2-85E1381A3743_1_105_c.jpeg D8C09078-B630-4C7E-94B2-85E1381A3743_1_105_c.jpeg](https://diysolarforum.com/data/attachments/2/2519-0a6961f76cf831fba50e4e21714aa72f.jpg)
This is the mobile barn I have...
![9C19F495-F7C5-4CCF-9ABC-86F8E28DF98F_1_105_c.jpeg 9C19F495-F7C5-4CCF-9ABC-86F8E28DF98F_1_105_c.jpeg](https://diysolarforum.com/data/attachments/2/2520-dc84bf804779f2d6987186f65c3dcc89.jpg)
I am using this mainly to power an electric fence, some lights and some electronics when I am at the barn.
![2AEE40F4-FBD6-40C4-8122-19ECC94F9AF3_1_105_c.jpeg 2AEE40F4-FBD6-40C4-8122-19ECC94F9AF3_1_105_c.jpeg](https://diysolarforum.com/data/attachments/2/2521-eb3d27324b4decada6f19a864d357f11.jpg)
I am pretty sure I've done all the wiring correctly but If I have done anything wrong, please send me a comment and i will modify the setup.
COMMENTS WELCOME!!!
Minimum : 3.0V
Maximum : 4.2V
Width: 1" (26 mm)
COMMENTS WELCOME!!!
