I'm considering purchasing a Power Star 24V Inverter/Charger model LW1000. I've been researching various systems and my understanding has significantly improved since i've started but i still have lots to learn. This post is as i currently understand but i may be wrong. That's why i'm turning to you guys/gals that surely have more experience and knowledge!
unpluggedpowersystems.ca
Here we go!
Thanks again for all the help.... looking forward to stepping out of the Research and development phase. The way i see it, purchasing the LW1000 would give me the ability to power up my cabin through my existing breaker panel immediately and still providing charging capabilities until i get solar panels and a charge controller. Hoping it makes sense!
CoachMcG
buy 24 Volt Pure Sine Wave Charging Inverter - 120 Volt AC Output -
Main Features 1. LCD digital display show voltage, load and battery info in real time. 2. Peak power is three times of rated power. 3. Can work with inductive load such as air conditioner, motor door and so on. 4. Pure sine wave output, available for sensitive load. 5. 4-step progressive...
![unpluggedpowersystems.ca](https://unpluggedpowersystems.ca/wp-content/uploads/2019/01/favicon.jpg)
Here we go!
- I believe this model would meet my short term (2-3 years maybe longer) needs. Since i can connect my generator to it, i have no issues running my generator to fire up the keurig machine, hair dryer, tools etc. If i understand correctly, when i start my generator, a transfer switch would disable the battery power and the power running through my inverter would now be supplied by the generator. At the same time, it would now be charging my battery bank. Correct?
- I have 4*12V Lead Acid AGM Batteries rated at 75Ah. If i want a 24V system, i would connect 2*12V in series and connect those in parallel with a second bank of 2*12V right? This setup would give me a 24V 150Ah=3600W bank... correct? if the inverter is only 1000W, does it matter if my bank is 3600W? I realize i can only use 50% so 1800W.
- I'm considering a small fridge. I checked and i could get a small bar fridge rated at 115V*1A=115W. Assuming i'm on the right track... 115W running i can multiply by 10 for peak so 1150W for start up. The LW1000 says peak is triple therefore 3000W start up so it could handle the surge of a fridge starting up as long as i'm just running lights... still doing good or am i completely off the rails? LOL
- Now for the battery bank and Watt hours (Whenever i see these appliance ratings... is it implied that it's Watt/hours? 15W light bulb would use 15W in 1 hour?) My understanding is that 115Wh was if the fridge would be running the full hour so i could divide by 4 assuming the fridge could run 15mins/hour. In other words, the fridge would burn 115watts in 4 hours. 1800/115=15.6 hours? I'm guessing i'm off here because i seem to recall a conversation with someone that a fridge at that rating could run for longer.
- Last question... for now ;-) How long would it take for the LW1000 to charge my battery bank with my generator. I see that there are various settings in the description (6. Fast and powerful charger with 20A/35A/50A/70A/90A. ) to charge and it says it can charge quickly. How does this work? If my generator outputs 115V and i set it a 20A it would produce 2300Watts in 1 hour and my battery bank would be fully charged?
CoachMcG
