Hi,
I've just ordered 8x 3.2v 280ah cells to make up a 24v battery for my camper conversion.
Do you have any advice for a bms with low temp protection?
I'm thinking about coupling the battery with an all in one mmpt/inverter of 2500/3000v to power an induction top.
I already have a sterling 70a dc-dc charger..
So I guess that that 150a/200a bms should be sufficient..
Do you have any advice on what BMS I should use? (Low temp control is a must)
In the end, with potentially 200a current going through the system, any must regarding safety/protection for me and the sistem?
Thanks
Thanks
