wattmatters
Solar Wizard
Agree.Without definitive terms we misunderstand each other.
Which is precisely why the use of the term "hybrid" to distinguish whether an inverter is capable of bi-directional energy flow with the grid makes little sense, creates confusion and misunderstanding. There's nothing "hybrid" about that particular feature. It's not a mixing or blending of anything.
That's not a technical definition. It's just a product statement.I did put in a huge pic with the definition With a red box. With the link.
I've been trying to find a definition in the literature but I'm not so familiar with searching electrical engineering papers (I'm not an electrical engineer).
There are papers where the term is used, for example many papers like this one talk about Hybrid multilevel inverters (binary, trinary etc):
In these papers the term "hybrid inverter" refers to the combination of various technical means of producing near sine wave output forms / reduction of distortion from variable DC voltage input(s).
I accept its use has been mangled. It happens a lot. Heck, "shock absorbers" in cars don't absorb shocks (they just dampen the motion of the spring), "coolant" added to cars doesn't help cooling (its purpose is simply to lower the freezing point and raise the boiling point of the cooling fluid, indeed "coolant" reduces the heat transfer capacity of the water its mixed with), and car "radiators" don't use radiation for heat exchange either.
